Thermostat question for gurus of TOyota
Old Jan 6, 2008 | 01:28 PM
pasha's Avatar
Guys,
I had a problem with overcooking so I changed t-stat, now my idle went down by about 100 RPM is that normal. Thanks for all your help.
Thanks Aot
Old Jan 6, 2008 | 02:55 PM
TORTIS's Avatar
might want to reset the ecu
Old Jan 6, 2008 | 06:41 PM
pasha's Avatar
thank you
Good idea thanks
Old Jan 6, 2008 | 06:57 PM
toytech76's Avatar
Make sure you have your cooling system burped properly. Air in your cooling system can change your idle as well as causing overheating. I don't think resetting your ecu will have any effect on it
Old Jan 6, 2008 | 07:17 PM
pasha's Avatar
I thought about it.
I dont think its possible to get a air bubble in this engine. Maybe I'm mistaken but anybody ever got air bubble in this engine?
Old Jan 6, 2008 | 07:19 PM
toytech76's Avatar
Sure it is. Do you know in how many passages your coolant needs to flow? Its very easy to have air trapped in your motor. Happens all the time if you don't burp it right
Old Jan 7, 2008 | 07:59 AM
pasha's Avatar
It worked!!!!!!
Mr. Tortis, you were right about ECU I reset it and it all back to normal. Thank you very much. There are no community like YOTA community.
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
