22RE Milky Oil...
22RE Milky Oil...
hey guys. i need a little help. drivin home and my truck got real hot. pulled into my driveway and engine shut off by itself... then wouldnt start after checked coolant... NONE checked oil... LIGHT BROWN MILKY. Wat did i do and wat can i do to fix this?
if its a 92 im guessing its the 3.0. you got the sickness man. blown head gaskets. good luck on that one. i have yet to get sick but the possibility is still there. sorry to hear that man. good luck on the fixes. search on here for some directions/ tips for changing them or tips for whoever will change them.
you know, since this guy needs a new head gasket, i figure id ask a question for BOTH of us... everyone knows these engines were made with asbestos, and when they stopped using it, the gaskets blew easier. now my question is: is it possible to get ahold of an asbestos head gasket still?
Research a machine shop that will make sure the head is flat and see what they charge to do a valve job just in case it needs one. If it's warped, the gasket will fail. Typically I lap valves and use these opportunities to install cams etc... However that's money you might not have.
Price your gasket set which will include much more than just the head gasket.
Search the site for other things to change while you are in there.
There are lots of performance related mods you can do but if you don't have the cash just cover the critical stuff.
And lastly, search because in the 20+ years since that engine came out, it's been fixed and discussed quite a bit.
Frank
x2. pull your timing cover and check the condition of the cover. This is an easy and cheap do-it-yourself fix if the chain chewed through a water jacket in the cover. Plenty of info onsite for this problem.
, it wont solve the problem. What motor is it?
heheheh
