Tried Searching, Need to verify steps to get Stereo out of '99
Old Jan 5, 2008 | 07:02 PM
psraff's Avatar
After lots of searching (on here and Google) I have just one or two questions on removing that front cover to get to the stereo. There are just the 5 clips holding it on, right? I have a "hook tool", but I think it's too big for this (it's for door panels, carpet, things like that). What's the best thing to use to not bust anything?
Also, on a '99 does the consol have to come out? Does anything have to be done with it to get enough room to slide the stereo out?
I'm working on getting a Scion (Pioneer) stereo for it and I would like to get this swapped out. I don't have a Toyota Dealership close to me to get clips or anything if I bust it up.
Old Jan 5, 2008 | 07:15 PM
Rock Slide's Avatar
The panel must be removed first before the radio can come out. I'm assuming you a double-din radio correct?
First, remove the panel around the gear shifter. Once that panel has been removed, starting at the bottom, slowly pry off the panel that surrounds the radio. You should be able to pull it out far enough to unclip it and then reach behind it to unplug all the electrical connections.
To reinstall, connect all the electrical connections back together and snap the panel back into the dash.
Once you've done it, you'll be amazed how easy it is. I've removed mine at least a dozen times to do radio mods on my '02 Sport.
Old Jan 5, 2008 | 07:18 PM
Rock Slide's Avatar
Here's a pic of my panel & radio removed:
Old Jan 5, 2008 | 07:22 PM
Godzilla's Avatar
this is a good writeup for removal of the panel.
https://www.yotatech.com/forums/f127...acement-70183/
Old Jan 5, 2008 | 07:42 PM
psraff's Avatar
Yep, I'm a double din. Alright guys that's all I needed to know thanks! Now to continue to try to get that Stereo. I'm up to a whole $15.00! heheheheh
(I'm sure it will get ugly tomorrow though.)
Blamalam
Mar 12, 2022 07:34 AM
theking11863
Mar 19, 2016 09:36 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ShakinIt2x
Jul 21, 2015 06:20 PM
smiley52
Jul 11, 2015 05:16 AM
