Broke down in the '86 yesterday...gathering input
So, I stopped at the feed store and went to leave, turned the key and heard something snap down under the vehicle....somewhere in the vicinity of the motor. You know how sounds can travel, so I wasn't sure at first. Tried to start again, but all I got was the starter cranking. The motor would not turn over. Called a Toyota tech at the dealer...real helpful..honestly. He said sounds either like the thrust washer (allowing the crankshaft to push forward from the clutch thereby misaligning the flywheel with the starter) or the starter itself breaking. Couldn't do anything that night, so I went back today. No play in the crankshaft pulley, so I mostly ruled out the thrust washer. Fortunately, the feed store's right across from O'Reilly, and so I got a starter. Took about an hour to change it out (tip: if you can, pull the oil filter off to work the top starter nut on the stud and can clear the fuel filter) with little luck. The motor now turns over, but very slowly and will not fire. I'm getting fuel and spark and air and all that jazz, though. One guy at the feed store suggested the timing chain may have snapped, so yanked the valve cover. Turn the crankshaft over by hand and it turns the timing chain and cam pulley. Still intact. One thing I noticed when pulling the vacuum lines to remove the valve cover was steam coming out. Unburned fuel in the plenum....not supposed to be happening. The even more crucial thing I noticed, though, was that when I turned the crankshaft by hand there was little to no resistance in the crank from would be compression. After telling a mechanic I trust all the symptoms, he said it sounded like a bent valve/s....which would explain no firing and no compression resistance. (BTW, had the battery tested at the place I bought it...which is fortunately right next to the feed store where I broke down....even though it's brand new. It tested strong. All my connections are intact and clean.) Anyway, the mechanic suggested....possibly...the bent valve theory suspecting the timing may have jumped from a "push pin/dowel rod" having sheared.???? In the process, the motor must have temporarily seized breaking the 7+yr old starter.
I've never done a timing chain and not familiar with this rod/pin, so does anyone have an experience such as this? If so, what can I look for? Also, how can I further deduce if the valve/s is bent without actually pulling everything apart just yet? When I get it towed homewards tomorrow, I will run a compression test.
This all happened completely out of the blue with no warning that I'm aware of. I have had some intermittent timing chain noise (with an associated slightly high idle) for a little while, but the guides are intact and I figured it was just some slack from the 70k age of it. Don't know if this even related to the recent event, but maybe.?????
Any input? Similar experiences? Need more info? Could you follow my post?
Thanks
Thanks
If you have heard noise from the timing chain then it is possible one of your timing guides broke and maybe the lack of tension made the chain skip a tooth but I don't think one tooth or two could cause a bent valve. I'm sure someone can maybe shed more light on this.
Hmmm....I suppose that's a possibility. The chain rattle has had my concern, but figured it could wait until I had the time....and warmer weather....to replace it not figuring it could possibly skip. I already have a front end kit for it.
The driver's side guide is loose, but not broken off. I did tell the mechanic about it, but he didn't seemed alarmed by that. I suppose I'll run the idea by him and see what he says. Hell, maybe it skipped more than one.
Thanks.
Thanks.
Found this article on checking slack for the chain. I believe I will do this today.
4.13: Checking slack on timing chains
Several methods for checking slack have appeared on the list. One of
the easiest ways to check is as follows:
Remove distributor cap and spark plugs (removing the spark plugs allows
you to turn the engine over much easier). Locate the crankshaft pulley
and timing marks. On many engines, the crankshaft bolt is 19mm. Turn
the engine over with your socket wrench on the crankshaft bolt until you
reach TDC or "0" on the timing marks. Turn slowly (in the opposite
direction) past TDC while watching the movement of the rotor (inside the
distributor). A movement of 10-12 timing degrees before the rotor
starts moving indicates excessive slack in the chain and necessitates
replacement. New chains generally have less than 5 degrees of slack.
contributing: Allen T "Koji" Kam (tkoseki@uhunix.uhcc.hawaii.edu)
Aaron Lung (lung@san-jose.ate.slb.com)
http://www.mr2.com/TEXT/toyotafaq.txt
Good luck with this. I’ll be interested to hear what you find out.
No, but without actually having the engine apart nor having done a compression test done yet I'm kinda making "best" guesses. Likely it doesn't have "no" compression as there is some, I suppose. But, compared to before this happened there might as well be zilch....lol. It's just way too easy to turn.
I spoke with someone today that suggested if there was no compression....or just very little....likely it would crank easier than it is.
I won't know any more than mere guesses until I start digging into it and testing things, but anyone with suggestions I'm open ears until then.
I would rather do a timing chain than a clutch!
you couuuld do a manual compression test by turning the crank by hand.
This is a weird one. Do you hear any noise in the motor when you hand crank it? I'd pull all the plugs and have someone hand crank it while I examined the pisto heads w/ a flash light.
I can't imagine the timing chain skipping a tooth w/out actually taking some teeth with it!
This is a tough one for someone who isnt familiar w/ timing but Id put the motor at TDC and check where the rotor in the distributor lands. I personally know where it should be .. which is like 35 counterclockwise from 12 oclock.. ah its hard to describe. But it should land on #1.
I think if I couldnt find anything wrong with how it cranks or sounds and its not throwing codes and is getting fuel/air and the plugs are all gapped right (0.031" fyi) and not fouled.... Id pull the oil pan before I went into the front cover or pulled the head.
You can hand crank it with the pan off and probably hear/see more.
It's hard to diagnose this one without actually having my hands on the motor.
Man. That sucks. Sorry to hear of your troubles. Wish I could give you some guidance, but it sounds like you have pretty much hit on all the possibilities. Horrible weather to be working on a rig. Good luck and keep us posted.
Thinking out loud here, thook...would a possible (and easiest) way to check if a valve is bent - with the head still on - with the valve cover off already - take the exhaust manifold off, spray a carb or brake cleaner through a valve port and see if it leaks out the other side?
I used this technique (mind you with the head already on the ground) when checking my valves after a timing chain failure.
I dunno, perhaps the least invasive.
Thanks for all the replies, guys! (Hey, that rhymed....
There are many, many things I'd rather do, also....and NONE of them have anything to do with a vehicle.
But, I can't complain really. This whole thing happened in a very fortuitous way. I mean, aside from the eyeball freezing wind the past couple days (thanks for the sentiment Kyle), the circumstances could have been a lot more challenging. I broke down at a place where I know everyone (for almost 15yrs), so the vehicle was safe and no inconvenience to anyone. The parts store was a 2min walk. The fellow that towed it yesterday has his shop a mile from my house and will let me work on it there....albeit out on the grass. (The shop's only so big for paying jobs). And the fellow, his son, and co-worker are all friend's who'll lend me advice and tools as necessary.
The son and I had a look at it once it was towed to the shop, and since he has an extra cab and has done everything that could be done to a 22RE his troubleshooting skills are much more honed. The motor is not building enough compression...if any at all....to fire the cylinders. It was way too cold and windy (plus little daylight left) to pull the valve cover and look at things real well, so I'm not sure what all's going on, yet.....as in how it happened, IF that's what's happened. I won't be able to do anything until next week. But, Greg (the son) said I could pull the rocker rail off so that all the valves close shut and run a compression test to determine if any valves are bent. He said even if the timing chain did skip (which is seeming very likely) it doesn't mean any valves are bent. I may have gotten lucky. Makes sense....I recall a thread here fairly recently where a guy's chain broke yet no valves bent. We'll see. Plus, since the v-cover will be off as well as the rocker rail.....if no valves are bent.....I can do the timing chain (the whole front end, actually) and replace the valve stem seals all at the same time while leaving the head and bottom end alone.
Speaking of the bottom end, here's some good news. I don't know if any of you all know about or remember that I had started a thread a little while back where I was concerned about blow by and the rings on this thing. Greg point-blank told me that if the rings were bad enough to create blow-by it WOULD get smoke and I would NOT get the compression readings I got. Soooo, I don't HAVE to do the rings....which I was my original intention when I did the timing chain this spring. My PCV valves is probably just not shutting well even though it appears to be okay. In the event the valve/s are bent I might, though.....plus head work and front end and anything else that looks in need of taking care of. We'll see.
Anyway, to answer some questions...
Drew, I don't hear any noise or even feel any grinding when I turn the crank by hand. There's no play in the crank, either. I did notice a noise once or twice when I turned the motor with the key, but it seems to be more towards the top end. Not sure if it was just fuel partially igniting.
I didn't notice that any teeth were broken on the cam gear, but I wasn't really looking closely or even for that when I had the cover off the other day. I was just looking to see if the timing chain was still in one piece. If I were to recall on what I remember seeing, I'd say no, though. If there was enough slack in the chain, however, it could still jump with necessarily taking any out in the process. I really am suspicious of the tensioner due to the aformentioned intermittent rattling. I know it's not the valves as adjusted them this past summer.
I'll take note of the distributor and cam gear condition and positioning when I get it all apart next week. The plugs are practically new and gapped properly. Not sure if they're fouled. Haven't looked.
And, yes, the crank turns very easily by hand but the motor cranks slowly with the key.
Thanks again. See y'all later.
)There are many, many things I'd rather do, also....and NONE of them have anything to do with a vehicle.
But, I can't complain really. This whole thing happened in a very fortuitous way. I mean, aside from the eyeball freezing wind the past couple days (thanks for the sentiment Kyle), the circumstances could have been a lot more challenging. I broke down at a place where I know everyone (for almost 15yrs), so the vehicle was safe and no inconvenience to anyone. The parts store was a 2min walk. The fellow that towed it yesterday has his shop a mile from my house and will let me work on it there....albeit out on the grass. (The shop's only so big for paying jobs). And the fellow, his son, and co-worker are all friend's who'll lend me advice and tools as necessary. The son and I had a look at it once it was towed to the shop, and since he has an extra cab and has done everything that could be done to a 22RE his troubleshooting skills are much more honed. The motor is not building enough compression...if any at all....to fire the cylinders. It was way too cold and windy (plus little daylight left) to pull the valve cover and look at things real well, so I'm not sure what all's going on, yet.....as in how it happened, IF that's what's happened. I won't be able to do anything until next week. But, Greg (the son) said I could pull the rocker rail off so that all the valves close shut and run a compression test to determine if any valves are bent. He said even if the timing chain did skip (which is seeming very likely) it doesn't mean any valves are bent. I may have gotten lucky. Makes sense....I recall a thread here fairly recently where a guy's chain broke yet no valves bent. We'll see. Plus, since the v-cover will be off as well as the rocker rail.....if no valves are bent.....I can do the timing chain (the whole front end, actually) and replace the valve stem seals all at the same time while leaving the head and bottom end alone.
Update.....
A few days ago I ran a compression test. Pulled the valve cover off and backed the valve adjusters all the way out so the valves would close. Tested #1 cylinder and zero compression. I don't know about the other 3 because I stopped there. No point really I figured. Time to tear it down. I've got most of the front end off so far. The rest will be this coming week.
The timing chain jumped enough so that the distributor sits at 2 o'clock now instead of 11 which would be terminal #1. So, the timing is waaaaay off. Undoubtedly there are bent valves, but what cause this to happen...the chain jumping....is still unkown. I had a dream I broke a cam bearing. No damage at all to the cam gear. Something must have seized throwing the chain off.....and breaking the starter. Cam bearing would explain it. We'll see once the head is off and I dismantle it.
Right now I'm looking for gasket kits. I have the front end already covered...just need the rest. Engnbldr, most likely. I'm reusing the headbolts as they are not TTY and have never been touched before. I didn't realize those forkers were so big...wooh! I'm also going to replace all the vac lines and small coolant hoses 'round the intake.
More to come....for those interested. I'll post comments and details once I know more. This is a learning experience, for sure. Never seen this happen.
very interesting
The chain skipping is seeming more likely now. If it moved that much somehow you could of bent some valves would easily explain the zero compression (as opposed to a HG failure).
I would definetly pull the head at this point. A little word of advice somtimes the heads take a lot of muscle to free em from the headgasket (block). I had to use my cherry picker to pull my brothers head off (that sounds funny) it wouldnt budge otherwise. Lil pressure and a plastic hammer and it came off.
Pull the oil pan as well (you'll want to anyways to get the front cover back on properly). Will give you a good look at the crank, bearings, pistons etc.
very interesting
<<<smart alec<<<Lol....yeah, the head is definitely coming off. The chain definitely skipped. And I'm positive one or more valves are bent. If you heard the way it sounds when you crank it....along with the other symptoms....you'd go,"Yep...that's messed up." The thing nagging me at this point is not knowing about the bearing cap/s, yet. I truly hope nothing is screwed beyond repair.
BTW, that raises a question. It occurred to me if the cam and journals need machining, that will make the cam smaller. Would this not affect the amount the power the motor would then produce....considering a larger "racing" cam (with larger valves, etc.) produces more?
Thanks for the tip on the head. It's never been off in 220k miles, so it probably will be quite stuck. If it comes to extreme measures, though, the vehicle's park 50 ft. from a shop where they have all kinds of goodies. It will come off! Rarrrgh!
The oil pan? Hmmmm.....maybe, maybe not. Since I'm pulling head, there won't be a problem securing the timing cover. The only thing about the pan is I'm still considering replacing the cylinder rings and the pan would have to come off to do so. Undecided. Reason? The front diff., of course, has to come down. That, mi amigo, will be quite a project. Not afraid of doing it. It will boil down to time and money. Compression before this breakdown was very good which should indicate the rings being in adequate shape. Although, there are alot of miles on them. Enggh....I'll think about it more after I get down that far. For now, all I want to think about is making chocolate chip brownies.
Thanks for the input, Drew.
Hasta luego!
