Driveshaft ?
Old Dec 31, 2007 | 11:24 PM
corvettelvr73's Avatar
Driveshaft ?
What is the max lift for a stock 85 front driveshaft?
Old Jan 1, 2008 | 02:43 PM
84on40's's Avatar
Solid axle or IFS? I have 7" suspension lift on my 84 and only streched the front shaft 2" I think.
Old Jan 2, 2008 | 08:12 PM
85 were Solid axle from the factory and i ddint want to know how much you got and how much you had to do to your drive shaft i want to know the amount i can get with a stock one.
Old Jan 2, 2008 | 08:31 PM
4Crawler's Avatar
I was fine with a 3.5" lift on my '85:
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseI
Usually 1 of 2 things will happen:
1. If your front suspension has lots of travel, the stock slip yoke will pull apart under full droop. Only fix there is a longer slip yoke.
2. Drive shaft length depends a lot upon the location of the front axle, move the axle forward and it'll need to be lengthened. Or with a lot of lift and not a lot of up travel and you'll need to lengthen the shaft as well.
And extending a front drive shaft is not the end of the world. Only runs about $100, depending on local shop rates. I had mine lengthened maybe 3-4 times over the years.
Old Jan 2, 2008 | 08:39 PM
fustercluck's Avatar
I had my shaft....uh....l...lengthened.
Old Jan 2, 2008 | 08:43 PM
camo31_10.50's Avatar
3in...or 3.5in..is the max i would go...POSSIBLY 4in...anymore and u will definately have to lengthen it...and it depends on what lift you get...like...trail-gear...allpro..marlin crawler...anything that has quite a bit of travel.....but then somethin like procomp....(which is like $300)...probably not..because it wont give you much travel....if i get a lift its what im going with...i dont need flex...i dont rock crawl...i go muddin...so i dont need much travel..
Old Jan 3, 2008 | 11:40 AM
bigarms23's Avatar
i would say than 4inch is the limit without lengthing the shafts
Old Feb 8, 2011 | 09:24 AM
Phudson's Avatar
Hi, I have a 4" front lift on an 85 xtra cab, and have done nothing to the drive shaft. Is there any chance that this is causing a noise that is driving me nuts?
What exactly does it involve to extend the drive shaft?
Thanks
Old Feb 8, 2011 | 09:42 AM
4Crawler's Avatar
Depends on what the noise is and when it happens. In 2WD, your front shaft should not be doing anything aside from sitting there.
To extend a shaft a little, a spacer will work:
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
For longer, you have to cut off the tubed section and have a longer piece of tubing welded in place, then the shaft is trued and balanced. Typically done at a drive line shop:
- http://www.4crawler.com/4x4/CheapTri....shtml#Sources
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
