Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
Spring over
Old Dec 18, 2007 | 11:58 AM
premirrider's Avatar
Spring over
Whats is all needed to do a spring over on a 62 series Cruiser? Also with the spring over willl I be able to fit 35's? Thanks in advance.
Old Dec 29, 2007 | 11:29 AM
ffx60's Avatar
35s should fit fine. There is a ton of info on this at Ih8mud You may be able to run 37s pretty easily.
Old Dec 29, 2007 | 11:41 AM
fillsrunner4's Avatar
New pearches. you could get some from Marlin or even some local shops should have some. Probaly new shocks too
Old Dec 29, 2007 | 12:02 PM
ffx60's Avatar
The big part is cutting and turning the front axle. Perches, longer brake lines, some do a shackle reversal, I believe most need to swap out the front driveshaft as well. High steer kit too.
Old Dec 29, 2007 | 12:03 PM
ffx60's Avatar
Depending on how much life you have in your stock springs, you may need to add a leaf as well
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
83
Sep 27, 2015 04:13 PM
