how do i disconnect the tie rod?
Old Dec 3, 2007 | 01:30 PM
mcerwing's Avatar
how do i disconnect this?
i've tried heating it, pb blaster.
i'm supposed to hold the post and turn the nut, right? bc i keep trying that, and it's not working.
Old Dec 3, 2007 | 01:45 PM
thook's Avatar
No, the nut is a locking nut. You turn the "sleeve" to get the tierod out.
Old Dec 3, 2007 | 01:49 PM
mcerwing's Avatar
so i hold the nut and the sleeve and turn, right?
or am i supposed to somehow hold the tie rod end?
bc i've been holding the nut AND the sleeve, and turning the side in the picture closest to me UP, and i've been getting nowhere. this thing doesn't want to come loose.
This was supposed to be quick lol. just change the tie rod end. now it's taking forever and i have to go to work soon.
Old Dec 3, 2007 | 02:05 PM
thook's Avatar
Once the lock nut is loose, and since the tie rod is on the vehicle, you'll have to hold the sleeve with a pipe wrench (the best) or channel locks or vice grips and turn the tie rod with another pair of previously mentioned implements of destruction. If it won't budge, likely you'll be working on it for a little while. The threads have a strong tendency to rust because water and dirt get inside the opening in the sleeve. You will spend a fair amount of time getting all the rust out before you can install the new tie rod end. If this is the case, and you have the option, put in back together and do it another time...since you have to go to work. Note to yourself: when working on the vehicle with repairs and replacements, allow yourself plenty of freetime for conundrums such as this.
Old Dec 3, 2007 | 02:36 PM
mcerwing's Avatar
yeah... i thought 2 hours would be good.
but Murphy's law loves me....
i finally got the damn thing loose. the stupid locknut was stuck on there good, and some kicking got the job done lol.
thanks again for the help people
Old Dec 3, 2007 | 02:43 PM
thook's Avatar
Oh...good for you. My last tie rod end job took me nearly four hours. I had to take the old tie rod (with pipe wrenches and short cheater bars), cut the threads with a dremel tool, and chase the sleeve out with that and PB blaster. Yeah....real quick job. Fuhhh.......k!
You're welcome. Glad you got it.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
Gone Fission
Oct 7, 2015 12:42 PM
beltcutter
Sep 30, 2015 06:14 AM
