Double Pole Single Throw (DPST) Rocker Switch
Old Dec 2, 2007 | 07:53 AM
BajaRunner's Avatar
I got some of these for wiring up some lights and my compressor. I liked the look of them.
Anyways, I have been having a problem trying to wire them. There are 4 prongs instead of three, and it is is really throwing me off. When the switch is in the "OFF" position, I am getting a short circuit. When it is "ON", everything works accordingly.
My question is, do I need to be running 2 relays with one switch? I was planning on running 2 aux. light relays, but, I don't have it yet... I'd imagine it wouldn't be a problem, but, maybe it is.
Here's the wiring diagram (For a 6 prong (its a DPDT), I only have the bottom 4 prongs)
I've got the low amp hot wire coming in @ 5, and the ground @ 2. (Where my short is, and it makes sense since there is no resistance). And my pos output to the relay is @ 1.
Any ideas on what to do? Sorry, all the switches I've used just had 3 prongs and were straight forward
Old Dec 2, 2007 | 07:59 AM
mehret's Avatar
The schematic for a DPST switch looks as follows:
Each pin represents one of those switch ends, so you have to make sure you're hooking everything up right. do a continuity test and write down which pin is what.
Old Dec 2, 2007 | 08:09 AM
BajaRunner's Avatar
Right, I understand that its basically like two switches held together with one handle...
According to this analogy, you don't really need a ground for the switch, like other 3-prong switches then, correct?
Just a hot in, and hot out to the acc. relay, right?
I don't have a multimeter to do a cont. test, I need to buy one Thanks for the quick reply!
BTW- This is an LED light, so I guess they don't need grounds.. duhh..
Old Dec 2, 2007 | 09:17 AM
Nuthuts96's Avatar
From: Shelburne, VT previous: Everett, WA; Bellingham, WA
they're only 9.99 for a cheap one at sears. i got the digital one for 14.99 when it was on sale- definitely one of my best purchases! (used it countless times trying to diagnose electrical problems on my old 87 toy pickup.)
sorry i can't help with your problem, but just a push to get that meter! good luck
Old Dec 2, 2007 | 09:42 AM
BajaRunner's Avatar
Crap, I still cannot understand this!! What gives? I think I've tried every wire at every position. Maybe I just burned out the switch at this point.. haha.
Figures though, I always seem to screw up simple projects.
Old Dec 2, 2007 | 10:19 AM
Firefightertaco's Avatar
the only reason the switch would need a ground is if it has a light in indicating if is on or off
Old Dec 2, 2007 | 11:05 AM
BajaRunner's Avatar
Yes, it has an LED light. Did not know if they need grounds or not. I think they do, but, maybe not?
Old Dec 2, 2007 | 11:06 AM
BajaRunner's Avatar
So I tried using the other switch I bought. It works. The other one shorts out, and the LED does not work.... uhmmmmmm
mussy01
Dec 13, 2016 08:20 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
rjtrials
Aug 6, 2015 07:25 PM
crashburnoveride
Jul 10, 2015 06:39 AM
Gamble_STi
Jul 7, 2015 07:54 PM
