Yellow Top Optima Battery For Sale (NEW) D34/78 - D750U
Old Nov 26, 2007 | 06:43 PM
Guardian_Saint's Avatar
I have 1 New Yellow Top Optima Battery. D34/78 - D750U extension included. (1 week Sale Only)
Never been use or open. The Yellow Top Optima are good for off road lights uses or audio system.
$200.00 SHIPPED.
Battery Model: D34/78
Part Number: 8012-021
Nominal Voltage: 12
Design Function: High power, dual purpose engine start & deep cycle, for use in applications with large accessory loads
Plate Design: High purity lead-tin alloy wound cell configuration utilizing proprietary SPIRALCELL® technology
Electrolyte: Sulfuric acid
Case Material: Polypropyline
Group Size: BCI: 34
Length: 10" (254 mm)
Width: 6.875" (175 mm)
Height: 7.813" (198 mm) at the tops of the terminals
Weight: 43 lbs. (19.5 kg)
Terminal Type: SAE / BCI Automotive
Nominal Open Circuit Voltage: 13.1
Nominal Internal Resistance: 2.8 milliohms
CCA (0ºF cranking amps): 750
MCA (32ºF cranking amps): 870
RC (reserve capacity under a 25 amp load drained at 80ºF until voltage drops to 10.5 volts): 2 hours
Old Dec 3, 2007 | 09:42 PM
Have agreed to make the price lower to $180.00 SHIPPED, w/ a 24 month replacement warranty. The warranty is as follow on Optima Batteries website.
Old Dec 3, 2007 | 10:28 PM
olharleyman's Avatar
bring it down more and I may just take one. I can get one here for 145 no shipping and instlled in parking lot by employee of autozone.
P.S. do you have rewraps?
Old Dec 4, 2007 | 04:44 PM
If you found one for $145 then I think its better to buy it there? The wrap on the battery is still there. Sorry this is as far as I can go. The retail to this battery is worth 244.00, ebay is around 170 to 180 w/ 40.00 to ship.
Old Dec 4, 2007 | 07:47 PM
jjrgr21's Avatar
the MSRP is 180
Old Dec 4, 2007 | 07:56 PM
Brendan's Avatar
$174 shipped http://www.invertersrus.com/optimad34-78.html
Old Dec 4, 2007 | 08:00 PM
bob200587's Avatar
They sell for $180 off the shelf at most places, probably cheaper at the interstate warehouse. I don't think you got a very good deal on yours....
Old Dec 4, 2007 | 10:14 PM
DeathCougar's Avatar
Everyone here is correct.
the more expensive battery is higher CCA (Cold cranking Amps) Which means, basically, its a better battery.
YES you can find them cheaper. But they are lesser quality batteries. All optimas are NOT created equal. there are several different types and sizes.
Check optimabatteries.com for specs and such.
Old Dec 4, 2007 | 10:16 PM
btw most commonly sold battery is the 34-78, which is only 750 CCA. they make up to a 900 CCA yellow top. they also make a 35-78 which is only 650 CCA.
*KNOW BEFORE YOU BUY!!!*
80Truck
Oct 12, 2025 07:25 PM
jasonty
41
Dec 23, 2018 01:00 PM
montanatruck
Feb 26, 2017 07:07 AM
94whiterunner
9
Sep 22, 2015 07:28 PM
jackiebrownia
Jul 20, 2015 09:02 AM
