just installed 63 chevies in rear
Old Nov 18, 2007 | 10:21 AM
weakyota91's Avatar
I just got my rear springs in the rear but. my concern is when i welded the front perches in I could only get to 3 sides. the perches are pretty long i got about a 8 inch very clean bead along the outside and 2 inch front and back. but i couldnt weld the inside due to the gastank on passengers side and exhaust on the drivers side. Is this something to be concerned about when flexing out and adding pressure on it??
Old Nov 18, 2007 | 01:37 PM
Spinnbait's Avatar
yes and no
Ideally, all four sides should be welded, but you can drill two 9/16" holes in the bottom of each hanger (don't go through the frame) and weld/fill the holes.
Old Nov 20, 2007 | 01:48 PM
-TheBandit-'s Avatar
That's what I did and it's held up fine for several years of abuse.
Old Nov 20, 2007 | 03:51 PM
sschaefer3's Avatar
That is what pretty much everyone does. On my 4Runner I have the passenger side fully welded and the driver side like you said. It has been beat so hard the engine started to dis-assemble itself. You'll be fine.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
rushw
Jul 18, 2015 01:46 PM
skoti89
Jul 6, 2015 07:45 PM
wilbertd
Jul 6, 2015 07:39 AM
