BJ spacers vs. Cranked T-bars
Just bought a 2 1/2" lift springs and T-bars (ironman) for my Surf. To even things out in the front what is the best option?
1> Crank the T-bars & install Low-profile bump stops OR...
2> Install BJ spacers, leave the T-bars alone (low-pro bump stops again?)
I don't rock crawl & I have warn manual hubs. Most of my driving is on gravel fire roads to get me to the mountains for play. (I do like driving really fast on those roads though....) Usually the only time I have my truck in 4WD is when it's REALLY icy on the roads up here.
Thanks for all the help everyone.
-frozen
-frozen
I'm not just saying this because I make the spacers, but the spacers with uncranked bars will ride and flex much better. I have ran both setups so speak from experience. Use them with stock extension (UCA) bumpstops. You can use low pro compression bumpstops.
Frank
Frank
It depends on which bumpstop. The extension stop should be stock. This is the upper bumpstop that limits how far the tire can droop. If one already has low pro extension stops, simply shim them up a bit. You can try running low pro extensions but you run the risk of binding CV's at full droop so it is operator beware.
You can use low pro compression bumpstops (the lower ones the LCA's hit) with no issues. I run them on my truck.
Frank
Frank
i had the bj spacers because i do NOT want to crank the t-bars. reason is excessive t-bar crank will cause the CV binding.
sorry i have a hijack question for frank, do you have a part # for the bilstein 5100 shocks which works the best with bj spacer? i've been searching for a long time for that.
Not all 33X12.5's are 33" tall and 12.5" wide at the tread. You can usually get exact dimensions from the manufacturer's sites. That said, you will see some people who squeeze them with little rubbing to those who have either pounded their fender seams quite a bit, installed a body lift, or a combination of both.
I wish I had a collection of what tires rubbed with which lift combos but I don't. That said, if you have some rubbing, and minor hammer operating won't cut it, you can still add a body lift to fix the problem.
I'll see if I can find that shock part number.
Frank
Frank
This is proving to be a bit of a challenge. I'll return to it in a few hours when I have more time. I have been browsing here http://www.bilstein.com/offroad.php#5125
Frank
Frank
If you keep your CV angles reasonable, it'll be hard to break them.
They are just as strong as a stock toyota straight axle.
I ran 33x12.50s for a year. They rubbed like a monster.
If you flex a bunch, this lift will not help you fit any larger tire than you did stock. If you just run on the street, it will.
Okay, bear with me here, how is the LCA on the T-bar lift down 1.5" compared BJ spacer lift? The LCA is down either way to provide the lift in either case since the spacers are on the UCA, is it not?
http://www.4crawler.com/4x4/ForSale/...ntSpacer02.jpg
i believe that if the t bars are relaxed, that uca will move up more than the lca will drop, i would go with bj spacers anyday before i would crank t bars y. i have 1.5" spacers. they give no rub clearance, and better on and off road performance than t bar crank, and easier on front equpmt. just my opinion.
edit: doh! you beat me to it
The difference when the vehicle is at rest as far as CV's are concerned between t-bar cranking 1.5" and spacer lift of 1.5" is nill. The difference is when the tire is at full droop. With spacers it is drooping 1.5" farther. While that does stress the CV's, the tire is drooping because there isn't any weight on it and therefore load on the CV.
That 1.5" more travel is a large part of the benefit of the spacers
edit: That's what I get for not refreshing my browser... sorry for redundantly answering the question.
Frank
Frank
