RPM interferance with Sub Woofers
i know my stereo is wired completely wrong, but everything works properly. My truck is a 3.0L 5speed 1988 4runner with a SAS, and once in a while when the RPM's go over 2000/rpm i can hear a buzzing in the tweeters or the subs or something, and gets higher pitched as the motor speeds up.
Could it just be a bad ground wire or what could my problem be? im planning on redoing all the wiring soon, but for the time being i want to fix this problem.
Any stereo guys know whats wrong?
I was in the high end car/home audio business for several years.
I did everything from car installs to running the place.
Just about all electronic ignitions produce some amount of RF.
That whining sound that increases with RPM is a common symptom of interference from electrical ignitions.
It is especially apparent when you add amplifiers.
Shielded RCA cables and a filter should do the trick.
If he was running 12v to the speaker he would be hearing something completely different, would also be smelling something burning...
or do this take the rca's from the back of the radio strip them take a wire around the outer wire and put it to ground there you go its a installers trick hope you like
to add, a clean power source (as close to (or directly to) the battery as possible.
fuse it by the battery and before the head unit/and amp.
i run my stereo on an isolated post on the battery itself, and every ground is less then 5 inches, to a bare metal surface (w/sandpaper) and then coated w/paint after securing said grounds.
never heard a buzz since ive been doing this.
also, to help w/dimming lights, try a capacitor (1.5fared is enough).
keep it simple, and keep the fuses in a convenient place *(i now use circuit breakers).
