Will 22re Knock sensor work in a 3vze?
I saw this and was wondering if anyone could confirm or deny it? Are they really interchangeable? I belive it would fit but wouldn't the signals be different?
Toyota 22re and Toyota 3VZE V6 used Knock Sensor tested good. Will fit Toyota 1985 on up 4-6 cly engines.
Well my answer is. So far so good.
If you stay with your model year range then you don't have to mess with switching plugs for the KS. It's only been in for about an hour but if anything changes I'll update this post for reference.
'93 4runner 3vze AT 2wd <- with '90-'95 22re KS
If you stay with your model year range then you don't have to mess with switching plugs for the KS. It's only been in for about an hour but if anything changes I'll update this post for reference.'93 4runner 3vze AT 2wd <- with '90-'95 22re KS
voiddweller
19
May 2, 2016 09:10 PM
1985, 22re, 3vze, 3zve, 93, code, compatibility, compatible, copatability, knock, location, locations, sensor, sensors, toyota
