Just replaced valvecover gaskets
Old Oct 26, 2007 | 08:41 PM
98runner210's Avatar
Just did the valve covers, glad to see the inside was spotless. No sludge at all.
[IMG][/IMG]
Old Oct 26, 2007 | 09:14 PM
MARSHALLMAY's Avatar
i need to do the same, i have some seeping...
how long did it take?
Old Oct 26, 2007 | 10:01 PM
Skrillah's Avatar
and how many miles do you have on your engine?
Old Oct 26, 2007 | 10:37 PM
ozziesironmanoffroad's Avatar
looks quite clean... im scared to take mine off... lol. afraid of what i might see in there. (or might not see...)
Old Oct 26, 2007 | 10:40 PM
Knuckles's Avatar
what brand and weight of oil do you use?
Old Oct 27, 2007 | 05:52 AM
MTL_4runner's Avatar
Wow, you aren't kidding......that is about the cleanest 5VZ-FE I have seen with any miles on it.
Good job on doing the head gaskets yourself.
Judging from the amount of rust on the engine components it looks like you live some place warm and dry.
Old Oct 27, 2007 | 06:08 AM
I use Castrol GTX 10W-30. I have torn down engines that ran Castrol and they were always clean. It took about 3 hours to do both sides. The passenger side is easy. You just take the intake tubing off. The driver's side requires removal of the upper intake. It comes off in 2 pieces.
I have 73,943 miles. I remember cause I just did an oil change LOL.
I live in San Antonio and the previous owner lived in Houston, so it rarely sees any salt. I may take it to Chicago this year though.
Old Oct 27, 2007 | 07:18 AM
BajaRunner's Avatar
Nice!!
I have some pretty bad oil leakage right now, and am going to start from the top, and work my way down since there is just so much oil, I have no idea where its starting. It looks like its up there though.
I run Castrol GTX (10w-30) as well, I've always ran it, and its been great. I had close to 300k on my last 4runner. I switched to Synthetics and decided I to switch back to dyno.
Old Oct 27, 2007 | 07:22 AM
CTRJ's Avatar
I did mine at 140k and my engine was nice and clean like that too. I use the 5w-30 oil from our dealership (I think it's Unical 76 brand) and a Toyota filter and change it every 3-5k miles. It took about 2 hours to and is not that hard to do. I changed the PCV valve while I was at it too.
Old Oct 27, 2007 | 07:50 AM
n4ynu1010's Avatar
You must change your oil regularly
Thats a good thing
Old Oct 27, 2007 | 08:05 AM
BajaRunner's Avatar
Do regular auto-parts stores have the PCV valve?
Old Oct 27, 2007 | 08:48 AM
yeah it is like $6.99. The only thing to watch for is on the driver's side there is a wiring harnes that is inside a plastic housing. It runs behind the timing cover up across the valve cover and sits on top of the valve cover. When I pulling the valve cover off, you have to move that harness out of the way. The plastic was brittle and shattered into the head. I spent an hour checking to make sure there were no fragments in the engine. Best way to avoid this is to wrap the entire plastic housing in electrical tape before removing the valve cover.
Old Oct 27, 2007 | 09:01 AM
Those plastic wire loom protectors are on both sides of the engine between the valve cover and the intake manifold.
They do become very brittle over time so it does pay to wrap them in tape first.
Old Oct 27, 2007 | 09:19 AM
BajaRunner's Avatar
Wow, good thing to note!!
Old Oct 27, 2007 | 09:34 AM
n4ynu1010's Avatar
I second that , but can I remember it hmmmmmmmmmmmmm
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
87blyota
Jul 10, 2015 04:31 AM
