No drive to front drive shaft
1990 4Runner V6 A340h automatic trans. The transfer case will not drive the front shaft. Is the 4wd engagement all mechanical or is there an electrical switch on the transfer case that engages the front shaft?
Your automatic is the A340H it is manually controlled with a Electronic safety just like the transmission its self. the computer controls the electronic safety to prevent the tranfer case from shifting into or out of 4wd at speeds higher then 35mph. As far as i know, and the wiring diagrams indicate, this actually only applies to 4lo not 4hi. the electronic safety wont let it shift down to 4lo or out of 4lo at speeds greater then 35mph if you disconnect the solenoid on the tranfer case, its right behind the transfer case shifter, you can tell whether this is an ecu issue or a tranfer case issue. Because with the solenoid disconnected it should work as normal.
Jun 1, 2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
