Installing 1991 model 3VZ into '95??
Old Oct 25, 2007 | 10:09 AM
roundhouse's Avatar
I have a 95 4 runner 3VZ V-6 with a blown head gasket
(is there any other kind)?
I replaced the HG twice and still no compression in 2 cyls, so I have a cracked block or head. Plus I stripped the head on one of the bolts so I cant remove the head again.
Anyhoo, I think I have located a reasonably priced running engine, with the HG recall already done. The replacement engine is from a 91 pickup, comes complete with all accys, wiring harness and computer.
What problems will I run into swapping it into a 95?
Different wire connections? Different PS hoses? Different A/C connectors?
Old Oct 25, 2007 | 04:40 PM
brentcole5's Avatar
saying your gonna use the engine wiring harness off of your truck your going to need to use your old alternator, the plugs on the back of it are different. you need to you your old distributor. the knock sensor under the lower plenum will need to be changed to the 95 model style and seeing that you will be in there already just get a new one because it very importand, you can but shouldnt use the one off your old motor. depending on weather or not you just have an oil light on your dash or an oil guage you may need to change out the sensor on your new motor depending, its right in front of where your oil filter is. and i would use your original upper plenum because some years have a couple different water lines and such, but im almost sure thats it and if its not im sure someone will correct me, but yeah.
Old Oct 25, 2007 | 04:42 PM
brentcole5's Avatar
oh yeah when you pull your old engine just unbolt the p/s pump but leave the lines on it, it will work on your new one but just flop it over to the side where the battery tray is and ive found that to be the easiest way and as far as a/c im not sure.
Old Oct 26, 2007 | 02:28 AM
TNRabbit's Avatar
If you replaced head gaskets twice & still have no compression, you have a valve not seating....
Old Oct 26, 2007 | 09:18 AM
roundhouse's Avatar
The compression is down on two adjacent cylinders.
Im thinking there is a crack in the head, that I didnt see.
coryc85
Sep 9, 2015 06:24 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Yota.Jay
Jul 26, 2015 05:50 PM
TDonkey
Jul 26, 2015 10:14 AM
zd92655
Jul 5, 2015 04:25 PM
