Shift lag
Old Oct 23, 2007 | 12:51 PM
co4rnr's Avatar
Shift lag
I have to rev up to about 1200 RPM when I go from a stop to shifting into 1st. Is this normal or is there an easy way to fix this?
FYI I just instaled a new clutch and a rebuilt engine.
Old Oct 23, 2007 | 02:28 PM
the_supernerd's Avatar
Is this after you stop or while you are coasting to a stop? If the clutch system is in good shape, then it will still have resistance when going into first while coasting. It should not be difficult to get into gear if you are stopped. If it is difficult, the first thing to check is the clutch system. Eventhough you have a new clutch, it could be the hydraulic system. Either a bad master or slave cylinder or air in the lines.
Old Oct 23, 2007 | 03:25 PM
co4rnr's Avatar
clarification
I should have been more clear. This is at a stop trying to get rolling. If I normaly ease off the clutch and go for the gas the motor seems to bog down.
Old Oct 23, 2007 | 03:41 PM
You mean that the engine needs to be spinning at 1200 RPMs before the truck will start to go? I would say that is normal, especially if you have oversized tires. If I let out the clutch at idle, my truck will roll a little, but the motor generally bogs down. In 4Low it will not bog much and will drive at idle. If you wanted to be able to drive at idle, your best bet other than a V8 swap would be lower axle gearing or possibly a cam shaft designed to produce more torque at idle. Generally, a 4 cylinder engine is not going produce enough torque at idle to carry a heavy 4 wheel drive pickup.
Old Oct 24, 2007 | 04:39 PM
n4ynu1010's Avatar
It takes that for mine and its 2WD hehe to get off the line normal with pull so I would say thats ok
Old Oct 25, 2007 | 03:43 PM
co4rnr's Avatar
Boy that makes me feel a lot better. Thanks all~!
Old Oct 26, 2007 | 09:42 AM
n4ynu1010's Avatar
Happy Trails
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
creecher10
Sep 30, 2015 03:27 PM
