help, miss at idle,tuneup done
Just a newby here with my first Toyota truck,95 4runner 3.0 auto.
Has a miss at idle and before doing a compression check just wanted to ask if i can do something else,besides being told a have a burnt valve or broken spring?
Just put new plugs and wires in,she still has a dead sounding hole.#6 plug seemed wet, but it was hard to tell as they were very old.
any thoughts please ,
thanks
Dave
thanks
Dave
Motor Missing
Miss at idle could be a hundred things (well maybe not a hudred,quite)
Did you use aftermarket plugs , if so re-check the gap , .031 for the 3.0 and the aftermarket plugs I got were pre-gapped at .044 for that motor .
Check for Vacumn leaks , did you put a new cap and rotor on ........if not check them for carbon traces , TPS Maybe , test TPS and rule out , check timing and rule out .
Throttle Body clean ?
Just a few things to check for starters
Go here and access or download the FSM for your truck and the test specs for the motor and the various emission and PCV/Vapor Recovery controls :
http://www.ncttora.com/fsm/index.html
Here is a TPS walkthru that should apply to your 3.0 :
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Tps
Although I did get my TPS from Pep Boys but it was the original part believe it or not , I took the old one and it was identical part and manufacturer (go figure) and yeah it was a bit cheaper but that is the only time I have had that happen
thanks
Dave
thanks
Dave
Was #6 plug white, and the rest gray/brown? If it was, you may have a bad head gasket
Injector
Can't help you there man , I would say outside of a diagnostic check of some sort that the plug color would tell the tale , many say and I have learned that most problems with injectors are that they are dirty and the "Seafoam" you can use in your gas and to clean Throttle Body/Intake works well (you can use in oil as well for gunk and stuck rings).
Outside of that I am not familiar with trouble shooting injectors
, I will follow this thread and learn a few things maybe
ok # was wet and smelled like gas and i hope its a plugged or bad injector, otherwisw i`m getting new heads or a longblock for Xmas!
Dave
btw she revs fine and starts right up,and oil and coolant look ok.I read a lot about burnt valves and broken springs ,so thats why i asked if this sounded like it
Dave
Wet Plug
Dave
Dave
The compression check will tell the story , either way look at the simple stuff first and rule them out
Blamalam
Mar 12, 2022 07:34 AM
