How much lift?
Old Oct 11, 2007 | 06:50 PM
LJ_24's Avatar
How much lift?
https://www.yotatech.com/forums/f2/n...4runner-41848/
How much lift will I get running this setup? and whats the biggest tire size that i can run with this setup?
Old Oct 11, 2007 | 07:52 PM
Nate08's Avatar
With the topout spacer approx. 2" up front and with the CORRECT LC coils (1995 FZJ80's) approx 3.5" out the back after settling. you should be able to fit 285/75/16's with minor to no trimming.
Old Oct 11, 2007 | 09:19 PM
LJ_24's Avatar
Can i use the set-up above and the burtman industries setup at the same time?
Old Oct 12, 2007 | 07:33 AM
Nate08's Avatar
You'll kill your CV's assuming you have 4 wheel drive. They won't be a crazy retarded angle, it'll be bad, but not that bad. They will wear out ALOT faster, when I say alot, I mean ALOT ALOT ALOT. Steve Schaffer at Sonoran Steel suggest only using ther one topout pacer that is 3/8" thick. That will give you two inches. That is as high as you can go and have your CV's wear similarly to stock height.
Old Oct 12, 2007 | 07:38 AM
Nate08's Avatar
Try searching. No one realy does it anymore. They just make a new thread stating their question. What they don't realize is that the same topic was covered 500 times just days before. The search button is the best thing on this Forum.
Old Oct 12, 2007 | 07:46 AM
neliconcept's Avatar
2.5 inch preload spacer on tundra coils? thats stupid as all get out.
here is the thing. with ADD, your max lift without ripping outers and boots is pretty much 2.5 to 3" (3 cutting it close) going with a man hub setup 3 is about max to 3.5"
however youll blow inners with 3.5" with non add CVs and man hubs.
just keep the the specific lift specs for the front and stick with 2.5" and get a body lift if you want it taller.
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
