How much lift?
How much lift?
https://www.yotatech.com/forums/f2/n...4runner-41848/
How much lift will I get running this setup? and whats the biggest tire size that i can run with this setup?
You'll kill your CV's assuming you have 4 wheel drive. They won't be a crazy retarded angle, it'll be bad, but not that bad. They will wear out ALOT faster, when I say alot, I mean ALOT ALOT ALOT. Steve Schaffer at Sonoran Steel suggest only using ther one topout pacer that is 3/8" thick. That will give you two inches. That is as high as you can go and have your CV's wear similarly to stock height.
Try searching. No one realy does it anymore. They just make a new thread stating their question. What they don't realize is that the same topic was covered 500 times just days before. The search button is the best thing on this Forum.
here is the thing. with ADD, your max lift without ripping outers and boots is pretty much 2.5 to 3" (3 cutting it close) going with a man hub setup 3 is about max to 3.5"
however youll blow inners with 3.5" with non add CVs and man hubs.
just keep the the specific lift specs for the front and stick with 2.5" and get a body lift if you want it taller.
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
