External tach really necessary for idle adjustment?
The FSM says to hook an external tach up to set the idle speed but is this really necessary? I was thinking of having a buddy get in the cab and race the engine at 2,500rpm then I'll adjust the screw until they tell me I'm at 750rpm. Would this work?
Also, when setting the idle speed does the diagnostic box need to be jumped like it does when you are checking the timing?
The reason I ask about the jumping is, it doesn't say to jump the connection if you're reading the maintenance portion of the FSM. However, if you read the timing portion of the FSM it will have you jump the connection first and the next step is check the idle speed.
I believe that you are supposed to adjust the idle while it's jumped to ensure the idle is correct to set the base timing. The idle adjustment screw (warm) seems to be purely mechanical. I don't think it will hurt anything to adjust it further after you set the timing. Just make sure the idle is correct while setting timing. It is critical.
Blamalam
Mar 12, 2022 07:34 AM
