Power steering problems
I have an interesting problem. I have no power steering when my truck is in park. If I shift the thing into drive the problem goes away and I have steering again. But it is still sluggish. The steering will also improve if I rev the engine just a hair (1k or so) My fluid is full and I have no leaks. The pulley turns freely and the belt is tight. I'm drawing blanks.......
It would'nt be a problem if I never wanted to idle over rocks off road. But of course I do.
I have a similar problem. What are you using for fluid? I have had to find out the hard way that you are supposed to use ATF in the power steering instead of power steering fluid, and now I'm pretty sure my pump is shot.
I actually have no idea what is in it in the way of fluid. I just bought it. But I do know that you are supposed to use ATF and that the fluid is a red tint (good sign) but it looks mixed. No it does not idle down. I also do not believe it to be a vacuum issue. I just tore down my engine and reworked a head. I replaced any vacuum lines that looked questionable and made sure they were all fastened correctly. If the problem is the type of fluid, would draining the fluid and replacing it help? And if so, where would be the best spot to drain it. And method for that matter.
My steering gear box is TOAST thanks to me using PSF instead of ATF in the power steering res. I'm about to put on a a new gear box, but should I change out the pump too? How much more work would that be?
Is the pump leaking? Cause I wouldn't touch it if it isn't, it's probably still good then.
My pump isn't leaking.... I flushed and filled my ps pump with the good ole turkey baster method. It seemed to help things out some. What is the idle supposed to be set to? once warmed up my truck idles at 500 rpm. Normal??
And yeah that's too low for idle on the 3VZE(you have the V6 I assume). It should be 800 rpms +/- 50 rpm.
ah hah, Yeah the vacuum lines are right I double checked them after that was said. It could just be the idle speed. It only does it when rpms are at idle they ps improves at 800 rpm. Maybe that is the problem.
It's a Toyota thing. What's labeled as "Power Steering Fluid" at the auto parts store doesn't meet Toyota's specs. Only Dexron II/III ATF for Toyota auto trannies and power steering pumps. Or Toyota ATF, of course.
I believe it's because the ATF is less harsh on the internals and seals. Besides, it's just a better lubricant.
I have read that a good total system flush ....as opposed to just refreshing the reservoir.....can cure the symptoms. But, then it may just be related to your idle.
Upping the idle pretty much cured the problem. I turned the warm idle screw just past a full rotation and it idles at 850-900 (in drive) power steering deluxe. 1000-1100 while in park. Thanks for the help. And glad I started a useful thread
the pump doesn't leak at all... But the gear box leakes fluid all over the front suspension (is this a good thing or a bad thing for all those bushings?) I was running straight lucas PS stop leak for a while which stopped leaks until it got cold and busted a line
Well, if you do any reading you'll find that it's not really that big 'a deal in some vehicles. It all just depends materials whatever manufacturer uses in the hydraulic seals and such as to what fluid would be compatible.
One should use only PSF or ATF, never both mixed or transmission stop leak in PSF, or power steering stop leak in ATF.
My data
When I purchased my Toyota it had a slightly leaking PS pump. Attempts to solve were as follows:
1. Power steering stop leak. Actually worked for a few months.
2.Flush and refill with ATF. Did nothing to the leak. Same o' situation for the next year or so. Had to fill the reservior every other day.
3.Then decided I didn't care what I put in it, ATF or PSF, cause it was gonna end up on the ground anyway in a few days. UH-OH, bad idea. I went wheeling one time after mixing them. Kerplow! Pulley seal springs massive leak, drive home with no PS.
4.Power steering pump rebuild kit, and get this, fill with PSF only. I've had no issues for nearly 6 months. Works great!
