Power steering problems
Old Sep 30, 2007 | 01:53 PM
corvey's Avatar
Originally Posted by MudHippy
It's a Toyota thing. What's labeled as "Power Steering Fluid" at the auto parts store doesn't meet Toyota's specs. Only Dexron II/III ATF for Toyota auto trannies and power steering pumps. Or Toyota ATF, of course.
Then...
My hypothesis
One should use only PSF or ATF, never both mixed or transmission stop leak in PSF, or power steering stop leak in ATF.
My data
When I purchased my Toyota it had a slightly leaking PS pump. Attempts to solve were as follows:
1. Power steering stop leak. Actually worked for a few months.
2.Flush and refill with ATF. Did nothing to the leak. Same o' situation for the next year or so. Had to fill the reservior every other day.
3.Then decided I didn't care what I put in it, ATF or PSF, cause it was gonna end up on the ground anyway in a few days. UH-OH, bad idea. I went wheeling one time after mixing them. Kerplow! Pulley seal springs massive leak, drive home with no PS.
4.Power steering pump rebuild kit, and get this, fill with PSF only. I've had no issues for nearly 6 months. Works great!
I smell contradiction to what was previously said. So which is it?
Old Oct 1, 2007 | 06:43 PM
naadomail's Avatar
Just a quick word on the idle problem I was having. I was cruising around with my new idle adjustment all happy n stuff. Then I decided to clean out my throttle body. I carb cleaner and toothbrushed up the whole shabang. I started my truck. White smoke, sputtering, and then the carb cleaner was out and I was idling at 1500 rpm!!!!!!!!!!! Monkeys, I then had to readjust the idle settings I had worked so hard to perfect. However this time it was a lot easier. Oh and my rig runs better than ever WITH POWER STEERING!!
Old Oct 2, 2007 | 03:37 AM
GSGALLANT's Avatar
Originally Posted by corvey
Then...
Use ATF like Toyota says to. Yeah, it will work for a while with power steering fluid before developing leaks. It would likely work with brake fluid too, but you wouldn't consider using that, would you?
Old Oct 2, 2007 | 07:22 PM
corvey's Avatar
Hey Mudhippy, where did you get your rebuild kit for the power steering pump?
Old Oct 4, 2007 | 08:24 AM
  #25
n4ynu1010's Avatar
Gecko
I don't get it. Power Steering Fluid is not suppose to be used for powering steering, and Automatic Transmission Fluid is what you use to fill the power steering up with?
I like your Gecko there Corvey , and your sig , thats cool idea
Old Oct 4, 2007 | 08:30 AM
  #26
rdlsz24's Avatar
I think it's pretty much the standard now. My wife's '98 Saturn, my '88 Toyota pickup, and my '04 GTO all use ATF in the power steering pump.
Rob
Old Oct 5, 2007 | 07:00 PM
  #27
corvey's Avatar
How to you properly drain out the old fluid so I can fill it fresh with ATF?
Old Oct 5, 2007 | 07:23 PM
  #28
n4ynu1010's Avatar
Power Steering Flush
There may be better opinions out there but I always have dis-connected return line at gear box (usually a rubber line close to gearbox going to hardline (low pressure) ) and drain what comes out from pump end into pan , then I would put a longer line on the gearbox end (Leaving gearbox,Low Pressure) and lay it in pan , then I would have a helper (wife) start truck and move wheel back and forth slightly while I am pouring in ATF into pump , as long as you do not overfill pump while doing this the oil will not run back down dis-connected return line (which has pan under it anyway) and the pump will not run dry as well if your helper only turns the wheel a bit either direction.
Hope this helps and maybe someone has a better way but this is how I have always done it to change or renew fluid in a PS pump .
If you just drain and refresh what is in pump you still have the old oil in gearbox so this way you get it all .
Just watch the fluid leaving the hose from the gearbox and when the color is true then your done , re-connect the return line and re-fill.
Sleaker
Aug 26, 2020 06:03 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
