Trailer brake controler needs to go bye bye
I have one of those trailer brake controllers in my 4Runner and since I took the hitch off and I'll never be pulling a trailer the controller is coming out. Along with the controller there's a big ol plug for brake lights that was on the hitch that must also go. All the wires are pretty easily traceable so getting them out isn't a big deal but my question is how does this thing work? If I just rip it out will it affect my brake lights? When I got home today I noticed my brake lights were still on after I got out of the car. I shook the controller and they went out so there's obviously a short somewhere. I don't want to screw up my brake lights so if there's a certain way to remove this stuff please let me know.
Thanks as usual.
Thanks as usual.
to the best of my knowledge, the controller simply "sees" the brake light signal. You should have a wire running out of the brake controller onto a wire coming out of the brake light switch above the pedal. I can't for the life of me figure out why the lights stayed on, but I can almost ensure that removing the controller will only help the problem.
(Please feel free to correct me if i'm wrong)
When I was doing installs we would just tap into the brake light wire under the dash with a scotch lock connector, 12v+ at the under hood fuse panel, and use a self tapping screw at any convenient point for a ground, and run a wire back to the plug to activate the brakes on the trailer, unless the vehicle had a oem trailer wire harness than it usually was a matter of plug and play. Also if your rig was set up for travel trailer watch out for a 12v+ at the plug end these are usually constant hot. that can be a good place to put a 12 volt outlet to run other stuff i.e. spot light, BLENDER, etc.
I think the lights were coming on because the controller also sends power to the lights if the manual brake lever is pressed, therefore you are correct in thinking there is a problem there, and removing the controller should fix that.
Chris
Chris
priest16
15
Aug 6, 2015 07:43 AM
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
Aug 4, 2015 08:49 AM
JAMGarcia
7
Jul 31, 2015 11:46 PM
shadowbirdie
Jul 21, 2015 10:38 PM
