Pre 84 Trucks 1st gen pickups
How much lift can I do?
Old Sep 24, 2007 | 06:34 PM
redvette's Avatar
How much lift can you go without lengthening the drive shafts? I'll be installing 1 ton springs on friday and don't know if i'll need new shafts. It's an '81 4x4.
Old Sep 24, 2007 | 08:00 PM
4banginRunner's Avatar
4"s is about max b4 the front needs to be lengthened
Old Sep 24, 2007 | 08:54 PM
4Crawler's Avatar
Yes, 3-4" is about the max lift on the front, depending on how much flex the springs have. I was OK with the stock shaft and 3.5" lift, but when I reworked the suspension for more travel, I found I needed to lengthen the front shaft. Usually you'll run out of the relatively short stock slip yoke length before the actual shaft length is an issue (i.e the shaft will separate under full droop).
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
