95 toyota 4runner engine/tranny swap questions
I've got a friend who has a 95 4runner, vr4, limited 3.0 liter automatic and the head gaskets have blown and he's wanting to do a 22r/5speed swap. Is it basically just a bolt in swap if you use a carberator? Or will the transfer case not work? Any help is appreciated.
You will need to cut/weld new motor mounts on the frame, get a new trans/tcase, crossmember, drivelines, and many other parts. It is definetly not a quick swap in setup.
By the time you change all that would need changing, you would probably find that the 3.4 swap would not be that much more expensive. It would also be far easier to swap in the 3.4 (fewer components that need to be changed).
The other problem is that it is illegal to swap in an older engine on a road-going, licensed vehicle. That could become a big problem come time to sell the Runner, later.
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
JaredL
Jun 16, 2015 04:47 PM
