what does the trd 7th REALLY get me and how to tell if its working?
finally got my trd 7th wired up and working (I think), is there any way to determine if it is working and working correctly? other than it starts and runs with no check engine light?
also, does anybody know what the whole setup actually gets me? I know it squirts more fuel into the charger/intake, effectively richening up the mixture. but other than more fuel, what else does it do? timing? adjust stock fuel trims on the original 6 injectors?
after a quick test drive, it doesnt feel like it has any more power. the only thing it seems to have done is make my truck start harder, it cranks, fires up, idles for about half a second and then dies. when I turn the key after it dies, it cranks for about 2-3 seconds then starts up. seems to run fine after the second start though.
oh, and one more thing, whats the second connector that is ran out by the injector that is connected to the 7th ECU but nothing under the hood?
thanks for any info.
You might try sending Gadget a pm or an email. im sure he can offer advice or suggest a product to give you more control over the fuel system.
https://www.yotatech.com/members/gadget/
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
