Just did a compression test, what is the 5VZ 3.4 supposed to get?
Old Jul 24, 2007 | 09:21 PM
Texas_Ace's Avatar
Ok, I did search for this!
I just did a compression test and I was wanting to know what it should be/how my engine is doing.
Here is how I did the test:
I first let is warm up by idealing and then I had to make a trip to the store so I did that. So when I got back it was nice and hot. I then pulled all the plugs (they looked good but they are running a little hot as the MSD makes them?) and undid the ignition so that I would not have any problems with the test.
Now with all the plugs out and the engine still hot I hooked up the tester and cranked her over about 5 times to get a good reading. I then wrote it down and did it again. Wrote it down moved to the next cylinder ect?
All the pressures came up to 180 +/- 5psi.
What is the pressure supposed to be on the 5vz-fe 3.4?
Old Jul 24, 2007 | 09:25 PM
pruney81's Avatar
I'm no expert but that sounds good to me
Old Jul 24, 2007 | 09:32 PM
Texas_Ace's Avatar
Yeah i liked the fact that they seem to be within the spec as far as 1 not being a lot lower than the others. I plan on Supercharging it soon though so i want to make sure everything is in tip top shape.
I just can't find what the specs for this engine are anywhere!
Old Jul 24, 2007 | 09:37 PM
pruney81's Avatar
I can't say for sure but I'm sure someone will chime in. I think 180 is pretty much where it should be to be considered in like new condition though
Old Jul 24, 2007 | 11:16 PM
86tuning's Avatar
The important thing is the +/- 5psi. 175-185psi compression is good.
Consistancy is good. The variations from one compression gauge to another would make more difference... if your gauge isn't a pro quality gauge, or if it's been dropped, it may no longer be accurate. But the repeatability is still good.
I can't remember what the lower limit is for warranty purposes. It's something riddiculous like 125psi. If one of the cylinders showed that, your engine would definately be hurting. Like short-rodded by water ingestion kind of hurting.
Old Jul 25, 2007 | 12:18 AM
ARB1977's Avatar
Whats the milage?
Old Jul 25, 2007 | 10:30 AM
Texas_Ace's Avatar
Yeah, seeing a cosistant reading was something i was glad to see. so you know what the new spec PSI is for it? I am just woundering how well it has been taken care of.
Originally Posted by ARB1977
Whats the milage?
It has 125k on it and i just got it a few months ago so i am very curious to see how she was taken care of.
Old Jul 25, 2007 | 11:11 AM
RacerX's Avatar
You didn't list it, but did you pull the Fuel pump fuse?
The wet fuel in the cylinder could increase the reading... much like using oil in a "wet" compression test...
Old Jul 25, 2007 | 12:42 PM
Texas_Ace's Avatar
I could not figure out which fuse went to the pump so i just did it with it running but all the pressures came up the same so i don't think it did much to it if anything.
Old Jul 25, 2007 | 12:54 PM
surf4runner's Avatar
The important thing is the +/- 5psi. Consistancy is good.
^ what he said
Old Jul 26, 2007 | 09:11 AM
Weasy2k's Avatar
Like 200 200 200 200 200 140
with 50% leakdown Through crankcase breather Bye bye rings...
Old Jul 26, 2007 | 10:16 AM
Texas_Ace's Avatar
Ouch that is bad, so is it supposed to be 200 on each cyl.?
I just want to find what the compression is supposed to be from the factory. I have no idea how wel this was taken care of so i am wanting to see if i can get an idea.
Old Jul 26, 2007 | 10:21 AM
Weasy2k's Avatar
according to EPC
218psi is new
Min Prssure is 145psi
Diff between pressure should be 15 or less
Old Jul 26, 2007 | 10:22 AM
Texas_Ace's Avatar
Originally Posted by Weasy2k
according to EPC
218psi is new
Thanks, and where did you find that? I have looked everywhere!
So it looks like they took ok care of it but for 120k it is not bad. still good enough for a SC i think.
Old Jul 26, 2007 | 10:31 AM
Weasy2k's Avatar
Yea mine is at 125k mi but my s/c lost its bearings and i think that is why 1 cyl is now 140
I have the factory service Manuel infront of me here for my tacoma
Old Jul 26, 2007 | 10:41 AM
Texas_Ace's Avatar
Ah, i need to get one for my truck but can't find them for what i can afford..
Old Jul 26, 2007 | 10:47 AM
Weasy2k's Avatar
they are not cheap....send me an email johnny (at) sea2skytuning.com
i can help you out in regards to FSM
Old Jul 29, 2007 | 07:26 AM
SteveS's Avatar
Per the Toyota FSM 2001
With fully open throttle, and a full charged battery to obtain at least 250 RPM on a warm engine.
5VZ-FE
174psi or higher
145psi Minimun
Difference between cylinders 15psi
Bonus info
2/3RZ-FE
178psi
127psi
14psi
Old Jul 29, 2007 | 10:20 AM
Texas_Ace's Avatar
5VZ-FE
174psi or higher
145psi Minimun
Bonus info
2/3RZ-FE
178psi
127psi
14psi
Great, so i guess that means it is in pretty good shape for 125k.
I have got to get a FSM...
Old Jul 29, 2007 | 07:00 PM
SteveS's Avatar
They are handy documents for specs, but kinda pricey. I've used mine enough to feel I'm close to getting my moneies worth, but you can download a digital copy much cheaper. I do find the paper version a lot easier for quick reference around the garage.
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
Sidherish
Aug 2, 2015 01:42 PM
