Isr Mod Done Today,pics & What I Noticed.
so here it is,took me about 20 min doin it,lol pretty easy stuff really,when you got the tools and materials,dont ask about the brown color i just had this around so i took it.i dont mind about that swewer line color anyway.
as for what i noticed well i gotta say ,i defenetly notice somethin,more responce,and even better in higher rpms.other than that well sound louder.
and im satified for somethin that small to do. i recomend this mod for sure!
Shot with C2Z,D520Z,C220Z at 2007-07-24
Wow! A genuine 3.turd!!! OMG!!!....lol
Actually, it looks just fine. I like earth tones, anyway.
Congrats on the modification. I did mine a while back and like it, too.
ho yea and as for the small connection you see on top,they stick out like 2mm inside the tubing.and i used some high heat resistant silicone to seal everything up,i did not even had to play with the idle after. flawless.
did mine about 2 months ago. by far a good bang for the buck. most of my time was spent finding the materials. i also did not have to adjust my idle. yes it does work like a charm and the 3.O's aRe turds, and wont ever be but a polished turds.. good pics
i only tried it for few minutes but still,i drilled my airbox too and putted a k&n filter but i did this a while ago.anyway i cant really hear much of it cause i got my chief pipe mod along with the terminator muffler ,with no cat,covering every damn sound in the truck.
Only I used electrical conduit (scheduel 80) from Lowe's.
a few more horse-poo-wer out of it......
Seriously though....
I drilled my airbox, too. So, just keep your filter really clean and/or change it more often. It has a way of sucking in more junk.
yea i know,i always keep it really clean and oily. by the way its a nice setup u got there!
Maybe you are already aware of this, but I thought I'd mention it...just cause it's something I became aware of running a K&N. When it's dry and dusty....if ever it is where you live...you might consider changing your motor oil a little sooner than usual. I use an AC Delco when it's dry, but like to use the K&N when conditions are otherwise. I know it's a trade off on the extra umph, but the thought of fine dust getting through and into the motor is a tad frightening. K&N's don't filter very well when it comes to that.
Change it up? In what way? What's wrong with the way it is?
I was taking a closer look at my intake and I saw that there is a Y pipe comming from the airbox and that other box right beside it then that leads to the elbow/silencer.
How did you connect that?
It's been a while since I've seen a stock set-up myself, but as I recall that little box I think you're referring to comes out entirely. I could be way off...I'd have to go back and look at the removed parts. Tomorrow.
