'95 4x4 3.0 Intake Plenum Bolt/Lock Washer question...
Old Jun 24, 2007 | 01:37 PM
diverjeff200's Avatar
Hey everyone,
Plenum, intake, timing belt & cam sprockets off. Just have the crossover, exhaust, valve covers then heads. WOOT!!
Noticed while removing the plenum that the 4 bolts each have a lock washer on them. Unfortunately, it appears these washers are pressed on because I can't get them over the threads to replace them.
Always been taught that lock washer is a one time use item. Should I consider new bolts/locks? How important are other bolts in same situation?
Again, thanks for the help and ideas.
Respectfully,
DJ
Old Jun 24, 2007 | 02:10 PM
SoCalWheeler71's Avatar
They're okay to reuse, as long as you tork 'em to spec. Lots of the bolts on imports have captured washers.
Old Jun 24, 2007 | 02:48 PM
MudHippy's Avatar
Yeah, I've retightened mine more times than I care to remember, about to do it again to redo my valve covers. Never had them come loose after torqued. I do recommend using a little bit of the anti-seize on 'em, keeps the threads from corroding or galling.
coleypull15
Nov 3, 2015 07:41 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
good-ol-boy
Jul 31, 2015 05:53 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
Coreyr384
Jul 10, 2015 11:13 AM
