rearend main bearing
Old May 13, 2007 | 09:48 PM
XtraSlow_XtraCab's Avatar
So... while taking out the driveshaft for new u joints I checked out the slack in my rear end (where the driveshaft bolts on). Way too much movement, I think its time for a new main bearing.
Could this bearing have caused other damages as well?
Old May 15, 2007 | 09:20 AM
Swansen's Avatar
do you mean a U-Joint??
Old May 16, 2007 | 09:28 AM
rrmike's Avatar
I think he means pinion bearing(s)....
If the flange is flopping around you could try tightening the pinion nut some. If it's moving a lot then it's probably too late to try to fix it.
Bourbonblues
Dec 15, 2017 05:43 PM
YotaPagota
Sep 20, 2015 06:24 PM
djpg2000
Sep 7, 2015 10:36 AM
justdifferentials
Sep 5, 2015 06:52 PM
