rearend main bearing
Subscribe
May 13, 2007 | 09:48 PM
So... while taking out the driveshaft for new u joints I checked out the slack in my rear end (where the driveshaft bolts on). Way too much movement, I think its time for a new main bearing.
Could this bearing have caused other damages as well?
Reply 0
May 15, 2007 | 09:20 AM
do you mean a U-Joint??
Reply 0
May 16, 2007 | 09:28 AM
I think he means pinion bearing(s)....
If the flange is flopping around you could try tightening the pinion nut some. If it's moving a lot then it's probably too late to try to fix it.
Reply 0
