Runnin rich after Oil Change
Old May 7, 2007 | 06:18 PM
yotawheelin95's Avatar
So my dad changed the oil in my brothers 94 toyota pickup mated to an auto tranny. After a little wile the thing started blowing black smoke and idles rough to none at all. All that was done was the oil change and all the fluids were checked. I know its running rich but what could cause this i dont know what to fix or what to check
Old May 7, 2007 | 07:06 PM
Nothin?!!?!?! i need help here guys
Old May 7, 2007 | 08:37 PM
KevinInSac's Avatar
That's strange. Only thing I can think of is maybe it was to light of an oil... But I don' t see how that would casue her to run rich.
Old May 7, 2007 | 09:02 PM
95ToyotaPU007's Avatar
How many miles between the oil change?
a friend of mine went without changing oil for 20K+ miles and experienced the same problems after finally changing the oil.
Old May 8, 2007 | 05:10 AM
Yotapup's Avatar
Try resetting the EFI system.
Old May 8, 2007 | 09:11 AM
How do i reset the EFI system?
Old May 8, 2007 | 09:13 AM
Right now there is only 66K miles on it and he just bought it a little while ago so as soon as we got it changed oil and checked fluids.
Old May 8, 2007 | 09:18 AM
91TPU's Avatar
check engine light on? pull the battery cables for a bit to reset the ecu, then try and run it and see what happens...is it blue or black or white smoke, maybe you have a headgasket issue...
Old May 8, 2007 | 09:56 AM
rdlsz24's Avatar
What oil did you use? Did you change the plugs?
Rob
Old May 8, 2007 | 10:12 AM
TC22RE's Avatar
So, what engine? 22re? It may be possible that, when changing the oil filter, a sensor plugin was unplugged, or a wire was broken, if one of these was a temperature sender wire it may cause the problem you're having. Or it may be unrelated to the oil change, did it happen directly after, the the moment it was fired up? Or did it gradually come in. Could be lots of things, any more info?
Old May 8, 2007 | 10:40 AM
MMA_Alex's Avatar
well if you're looking to reset the ecu just pull the efi fuse from the fusebox on the passengers side fender for a few mins, but i doubt thats the issue.
Old May 8, 2007 | 11:12 AM
Not exactly sure but my dad says it happened after the oil change and he didnt do anything as i said before this is the 3vze hooked to a auto tranny
The truck is pouring black smoke and runs like crap. No plugs were touched only fluids were checked
Old May 8, 2007 | 11:24 AM
OSU4Runner's Avatar
wow...20k on an oil change!!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
horunner1x
Jul 10, 2015 06:33 AM
HRDC0R19
Jul 5, 2015 06:43 PM
