moving to vegas, any maintenance tips?
driving to vegas from south carolina in late july, should I change the coolant mixture to mostly water and some coolant due to the heat there, what about oil? I use 10W30 in the 22re now, should i go thicker? the truck has 125k miles and runs like a top. anything else i should do? thanks..
Wouldn't it be better to run slightly more coolant in hotter temps?
I'd make sure all your cooling system components are in top shape e.g. your water pump and your thermostat - no holes in your rad, and just keep your oil changed regularly. *maybe * during the really hot monthes consider adding a quart of 10w40 to your 10w30 oil change, but otherwise I would imagine you'd be fine on a hot day as long as everything is in tip top shape.
I think a 50/50 mix will do you better in heat as well as cold. Definitely check out your entire cooling system, and make certain your A/C is working well.
That's a trip (SC to Las Vegas) I'd like to make.
I'm doing a cross-country trip as well (Maine to SE Alaska) and I have done the following:
-50n recall (finally-need steering relay rod, new tie rods, new idler arm, new pitman arm)
-new 2.25" pipe + muffler from cat back
-New shocks (front & rear)
-Repaired broken rear leaf spring
-New 3 core radiator (new coolant too)
-New T-stat
-New PS Belt, new alt belt (kept old as spares)
-new upper & lower radiator hoses
-oil filter & oil change
-Trueflow Air filter
That is it so far, if I have time I might replace my valve-cover gasket and possibly the fuel filter
-New T-stat
Have a safe trip...and fun, above all.
And one more last thing..lol
If it's a been a while, a new fuel filter. There's crappy gas all over the country you might wind up having to use. On that note, a seafoam treatment all around plus a spare can for the trip.
crashburnoveride
Jul 10, 2015 06:39 AM
