Pre 84 Trucks 1st gen pickups
t-case e brake help
Old Apr 11, 2007 | 12:38 PM
4stAir's Avatar
t-case e brake help
hey guys, i swapped my 80 to a 5 speed with dual cases using a front range crossmember. now i need an e brake. is there any t-case brake i can use with this crossmember?
i cant the other crossmembers on the market due to the fact that the 5 speed pushed everything too far back for the factory mounting locations.
Old Apr 11, 2007 | 03:35 PM
jriebe's Avatar
I would suggest welding some angle steel on the side of your frame rails and repositioning the crossmember. This would allow you to run another xmember which is compatible with a tcase style ebrake.
Jon
Old Apr 11, 2007 | 07:02 PM
4stAir's Avatar
well rather than that i will just disc convert the rear axle and use a functional ebrake back there.
Old Apr 11, 2007 | 07:25 PM
Hayes's Avatar
There is a t-case e-brake kit you can buy that works better than the rear brake version. The kit uses your stock e-brake handle.
Old Apr 11, 2007 | 11:14 PM
4stAir's Avatar
yeah there are a 3 but none of them work with my crossmember
Rowdydudeman
Nov 26, 2015 02:17 PM
old87yota
Sep 9, 2015 12:39 PM
Scatterbrain
Sep 3, 2015 06:46 PM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
