Need help with wiring in a Mallory Hifire 6-AL
Need help with wiring in a Mallory Hifire 6-AL in my 90 3.0
I have a mallory Hifire 6-AL and a msd blaster 2 coil that I want to install into
my 90 extended cab. I have the 3.0 and a manual if that matters. if someone can point me in the direction directions for wiring this in it would be much apriciated. thanks
Shane
Shane
ok.. I THINK I might have figured it out. correct me if I'm wrong. on the ignition amplifier, the positive going to the coil is the black with red stripe, and the negative going to the coil is the black with the white stripe. so I would just cut the black/red and where it comes from the ignitor, I would hookup the small red going to the mallory box. and hook up the orange to the black/red connected to the coil. then cut the black/white and connect the white from the box to the amplifier side and the small black to the coil side. as for the battery, the large red and large black go to it. and the magnetic pickup is not used? and since I don't got a tach, I don't gotta hook up the tach wire. is this correct? please help! thanks
ToyoToler
Aug 8, 2015 08:43 AM
