Fan Removal kickin my butt!
Old Mar 31, 2007 | 02:53 PM
sts2usnss's Avatar
Trying to take off the fan but having a hard time. When I tried to remove the nuts attaching the fan/clutch assembly to the water pump hub the whole assembly just turns with the nut. I would think that holding the fan blades still would hold everything else in place so the nuts would turn but instead the fan turns when the pulley doesn't. If that makes any sense at all. I have a feeling I am nuking this out but where and how do I keep the whole assembly still so I can turn the nuts?
Old Mar 31, 2007 | 03:15 PM
sts2usnss's Avatar
Anybody have any suggestions?
Old Mar 31, 2007 | 03:24 PM
slacker's Avatar
you'll have to hold the waterpump pulley by HAND ... there is an sst for this , but obviously you dont own it .
usually , I will try squeeze the belt to the pulley .. and that helps .
Old Mar 31, 2007 | 03:28 PM
sts2usnss's Avatar
A sst?
Old Mar 31, 2007 | 03:30 PM
slosurfer's Avatar
are you just trying to remove the fan or the whole fan/clutch assembly? I think if you remove the fan first, you will have more room to hold the clutch assembly. http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
Old Mar 31, 2007 | 03:51 PM
sts2usnss's Avatar
Thanks Slosurfer, when it stops raining I will get back out there and see if that helps.
Old Mar 31, 2007 | 05:13 PM
CyMoN's Avatar
impact wrench is how we removed my buddys when we did the head gasket
coryc85
Sep 9, 2015 06:24 AM
jackiebrownia
Jul 20, 2015 09:02 AM
1996Taco
Jul 20, 2015 12:02 AM
jjrbus
Jul 19, 2015 02:06 PM
zd92655
Jul 5, 2015 04:25 PM
