1986 4runner help me please
Hey, how ist it going Yes, im a green horn (newbie) I have been checking this sight out for a while now this is awsome how its like one big sick family. any ways have a problem just pick up another 4runner it starts and idles great but give it gas and it bogs spits and sputters. swapped out tbs mas and ignition coil from the other 4runner still no change fuel pressure is 40 LOST please help thanks, newbie
x2 on thecheck the air lines. Maybe spray some starter fluid around the engine bay and see if you can get a rise in idle speed, then you can localze the leak.
I would definitely say you have a leak but....?
Hope this helps,
Jon
Hope this helps,
Jon
i am having the same problem but my truck (85 SR5 w/22re) wont hold an idle after it warms up but when the motor is cold it idles fine and drives fine when it warms up it spits and sputters complete with the occasioanal back fire it almost feels like its running out of gas but if ya floor it it kinda comes out of it let me know if thats the same with your truck too
damattman my truck wont really make adifference cold or warm i can give it about 1/4 throttle it will rev up but any more spits and sputs. well today check out tps plugs cap airlines etc had atiny leak on front injector so i figured it would be agood time to fix it. well when i took off the intake the back to intakes are real wet fuel the front two are normal any suggestions
thanx 4runnerx3 i had called a old boss of mine who is a sevice manager for a toyota dealer and he had asked his techs what they thought it may be he said the temp sensor for the ecu was well known for doing this exact thing and not throwing a check eng light but i didnt know where it was thanks a ton ill let ya know if that does it .........is there a way to bypass it ?
Jun 1, 2021 01:51 PM
nanhodges2733
May 29, 2020 03:28 PM
