TPS Setting
TPS Setting
Can someone please check their TPS setting on their good running 22RE?
I am trying to set my girlfriends TPS using my OHM Meter but the FSM settings are so vague.
Thanks a lot.
Thanks a lot.
I know you're going to get linked to 4Crawler's site so I might as well just do it lol:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Rob
Rob
I list my settings on the following web page:
http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment
Note that the test values are "vague" to some degree because there is a range of acceptable values. For example, IDL-E2 is anything less than 2300 ohms w/ closed throttle. So 1 ohm, 100 ohms, 568 ohms, and 2299 ohms are all less than 2300, so as long as the resistance reading is less than 2300, it is fine. Same with the other readings, the key is to have them all within range, not just to get one to some "magic number".
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
