After headgasket no fuel!
Do I need to Prime the fuel pump? Is there anything I need to do?
If carb cleaner or some flamable is shot in to the intake and the engine turn over for a sec it tries to run. Any help would be appreciate.
I miss driving it so bad.
What did you all take apart with the fuel system when you replaced the head gasket? Are you sure you got the injectors, fuel line to the plenum, etc put back correctly? It should fire right up.
Rob
Rob
Sorry it is EFI. Is the ground that your talking about the one that comes from the firewall to the area of the hook that bolts on the rear of the head?
We replaced 2 injectores and the fuel filter.
defrag4
Jul 31, 2015 10:50 AM
