Rear Recovery Points without aftermarket bumper
Old Feb 28, 2007 | 07:03 PM
EWAYota's Avatar
I'm looking at a easy way to mount a couple rear recovery points on my truck until funds allow to get a rear bumper with recovery points on the bumper. Can't always expect to be able to get pulled out from the front.
Just curious to see how everyone else has they're set up. Simple D-ring shackles through the rear frame holes or something else.
So let me know what you've got, pictures of them would be a great help as well.
Old Feb 28, 2007 | 07:10 PM
alexe's Avatar
a trailer hitch is what i have
Old Feb 28, 2007 | 07:46 PM
91ToyTrck's Avatar
I was going to say if you have a trailer hitch then you could buy one of those D-Ring mounts thaat plug into your reciever. I can't remember who had them, but I'm sure someone will chime in here shortly.
Old Feb 28, 2007 | 07:50 PM
garrett1478's Avatar
what about something like the shackle hangers sonoran steel makes? i know his don't fit your truck but maybe you could make some that do fit yours...
http://sonoransteel.com/store_shackle_hangers.html
Old Feb 28, 2007 | 08:16 PM
EWAYota's Avatar
I don't have a tow hitch on my truck, don't even know if it has a tow package. It does have a hole in the bumper to mount a ball hitch but I don't think you could pay me to try towing something off that.
This is from another thread I found researching:
Originally Posted by jx94148
I use a D ring shackle through one of the holes in the frame near the rear bumper.
Originally Posted by HBoss
Me too. I've got one on each side in the rear and a spare shackle in the Runner in case mine breaks or someone else needs one temporarily. Not exactly the same for a 2nd gen. but very close.
But I was looking for other options besides this. I have a feeling this might be the best way to go for now, till I have the money for a good bumper. This going to be good enough and handle a good tug?
Old Feb 28, 2007 | 08:21 PM
no... those are tie downs. i'm pretty sure you're not supposed to use those as recovery points...
Old Feb 28, 2007 | 08:39 PM
CyMoN's Avatar
most junk yards you can get trailer hitch for around 45$
Old Mar 1, 2007 | 01:41 AM
leebee's Avatar
there are two points on the rear frame that are pretty stout and can be used for recovery points. should look like the one that is on the front opposite your single hook.
lee
Old Mar 1, 2007 | 06:30 AM
Tacoclimber's Avatar
From what I understand, though, if you tried a snatch recovery from just one frame rail, you can tweak your frame. It's better to have both frame rails tied together, IE, a bumper, or a class 3 hitch. That way, the stress is distributed more evenly across both frame rails...
Does that make sense?
PM Rob (WATRD) about it. I believe he teaches classes on off road recovery techniques. At the very least, he'll be able to dial you in.
Old Mar 1, 2007 | 07:16 AM
GV27's Avatar
ooof- don't tell that to my Truck!
Old Mar 1, 2007 | 07:27 AM
norcalsvx's Avatar
i just use the stock bumper, ive had to use it a few times up in the snow
Old Mar 1, 2007 | 08:32 AM
GV27's Avatar
From what I've seen the stock bumper does pretty well. I've yanked a couple trucks by it and last year my buddy towed a full yard of concrete with the one on his Taco.
OTH, my neighbor's old pickup tore it off trying to pull his wife's 'Burban out of the snow - but it was really rusty.
Old Mar 1, 2007 | 10:02 AM
91TPU's Avatar
if i tried to tow anythng with my rear bumper it would be gone in seconds lol. i would assume as long as you tie the two rear frame rails together you could use those as recovery points
Old Mar 1, 2007 | 10:40 AM
tc's Avatar
tc
It was ghetto BIG TIME, but it worked ....
I used a short piece of chain between the two tie downs once when I didn't have the rear bumper on my truck ... The guy I was pulling out was stuck BAD and I was wailing on it.
I don't think I would recommend that method, but in an emergency, it seemed to work OK.
Old Mar 1, 2007 | 10:57 AM
Stomis's Avatar
If all else fails a D ring through your spring hangar is supposedly safe. I wouldnt do it though in fear of messing something up.
Old Mar 1, 2007 | 01:06 PM
ShortyzKustomz's Avatar
If a hitch from an 86 Yota will work, Mines coming off next week will sell for cost of shipping
Old Mar 1, 2007 | 03:04 PM
tc's Avatar
tc
Uh - no it's not. Neither is a strap around the axle. None of that stuff is designed for anything near that kind of loading.
Old Mar 1, 2007 | 03:09 PM
881stGenRunner's Avatar
be careful if you have to yank someone out with the hitch. At least try to use a strap instead of a chain...check out this thread for the carnage.https://www.yotatech.com/forums/f116/ever-broke-hitch-108008/
Old Mar 1, 2007 | 03:10 PM
Word. Not a good idea AT ALL. Again, you really should have both frame rails tied together somehow, preferably with a bumper or hitch.
Old Mar 1, 2007 | 09:03 PM
InternetRoadkill's Avatar
Using the bumper on a 1st gen is a really bad idea. The bumber ties to the body rather than the frame and it's really weak.
A trailer hitch seems like the best idea.
