Is this True (Oil Question)
Is it true that all 3.0 engines use oil. I used 1 qt in 3000 miles after having the compleat top end re done. I have no smoke, or any signs of oil on the ground under the rig.
Well I'll be....... Choices,choices,choices......Decision, refrain could back-fire, brutally. Oh burn oil, probability high, I'd venture to geuss, from pers. exp., I blame it on that sneaky oil(100% synthetic) I use. I also have rebuilt 3vze.
I can tell you that I was using 1.5 qts per 3k miles until I auto-RX'd the engine. Now the rear main oil seal leak has stopped and I'm down to a little less than a quart per 3k miles. I think the rest is maybe piston ring leak-by by with a few leaks from my front left cam seal which will get replaced if the timing belt ever goes...
1 quart is well within specs for oil consumption.should it or should it not whos to say.toyota says 1 qrt in 1200 miles is acceptable.mitsubishi says 1qrt in 1000 miles is acceptable.neither would be acceptable to me,but 1qrt in 3000 does'nt concern me a bit.heck,its time to change it then anyway
You have to remember that even though the top end is new the rings and cylinder walls are old. Many times a new top end will increase oil consumption (puts more stress on the rings since everything is now sealed up top). Still, 1 quart every 2-3K seems reasonable to me and is probably not enough for you to notice any smoke.
I agree with the above. Mine doesn't seem to noticeably consume oil. At least it didn't before. It just leaks now.
My wifes Camry uses about a quart every 5000 miles. I discovered that once when I didn't change the oil on time.
I know this is an old thread, but I'll chime in with my observations.
First 1qt/ 3000 miles is certainly acceptable for an old engine. even if the top end was redone.
second, this rate of consumption usually won't create visible smoke.
I hope that's extra virgin....
