A/C Problems
Old Feb 8, 2007 | 04:02 PM
Cid_4r's Avatar
A/C Problems
Hey guys. I have a 95 4Runner, 3.0, 4x4.
my a/c has decided to stop kicking on. the compressor is not locked up. i can run the hot lead from the clutch coil straight to the batter and the clutch will engage and start cooling, but it will not engage using the switch inside the truck. the freon level is correct. is there any sort of sensor or relay that could have died on me... if so, where would they be located?
thanks again,
cid_4r
Old Feb 8, 2007 | 04:18 PM
Robrt32's Avatar
I assume you have checked the fuses?
Old Feb 8, 2007 | 04:38 PM
Cid_4r's Avatar
re: a/c
i didn't see a fuse labeled a/c or anything like that... any suggestions?
Old Feb 8, 2007 | 04:51 PM
ChickenLover's Avatar
The a/c fuses are located on the passenger side, under the dash.
Old Feb 8, 2007 | 05:35 PM
Cid_4r's Avatar
I looked under the passenger side, and did not see any fuses. Do I need to remove anything to see them?
Thanks
Old Feb 8, 2007 | 07:47 PM
Cid_4r's Avatar
nevermind. i found it. i was only removing the glovebox before. not the whole assembly.
there it was. a blown fuse. thanks again...
Old Feb 9, 2007 | 08:48 PM
PirateFins's Avatar
glad to see you fixed it. Now can you please turn it off, your making it to darn cold outside!
MO transplant
Apr 23, 2023 11:58 AM
stock87yota
Jul 31, 2015 10:08 AM
jackiebrownia
Jul 20, 2015 09:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
bryan34w
Jul 6, 2015 05:53 PM
