Spark Plug Wire ?'s
Old Feb 6, 2007 | 09:50 PM
Cobra123089's Avatar
Spark Plug Wire ?'s
i was wondering if anyone made spark plug wires bigger than 5mm for a 2.7 Tacoma. Also can the stock coil pack support bigger wires? TIA -Steven
Old Feb 7, 2007 | 05:37 AM
midiwall's Avatar
Here are a couple of threads I found by using SEARCH:
https://www.yotatech.com/forums/f2/plugs-wires-75356/
https://www.yotatech.com/forums/showthread.php?t=75356
https://www.yotatech.com/forums/f2/whos-got-best-deal-going-plug-wires-50570/
There _are_ larger wires out there, but the general consensus is that when we're talking about a stock ignition setup, then a good set of stock diameter wires will give you as much kick as a cheapo set of larger wires.
Coil pack wise, yeup, you'll be fine. A larger diameter wire won't draw more current, it will only let more current flow.
Old Feb 7, 2007 | 06:20 AM
MTL_4runner's Avatar
Ditto to what Mark said, even on a supercharged motor, the stock wires are fine.
Old Feb 7, 2007 | 07:18 AM
Elton's Avatar
x2 on the above posts
sandyota
Feb 4, 2021 11:16 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
