22R-E Head Question.
Old May 10, 2003 | 10:57 AM
tystoy's Avatar
What is the difference between a 22R-E head with round ports and one with pear shaped ports?? Anybody know??? I need to find out if they are interchangeable.
Old May 10, 2003 | 11:37 AM
atarinaper's Avatar
depending on your year of 22-re depends on the head... i believe.
Old May 10, 2003 | 08:03 PM
toyota parts dude's Avatar
22re heads
the heads with the round ports are from 81-84 and the ones with pear shaped ports are from 85 and newer. you can't use the round port head on a engine with the pear shaped ones or vice versa. in 85 they redesigned the engine internally. the 85 and newer engines the block is a 1/4 inch shorter. the newer head when you put it on a older engine the pistons will hit. so you need the exact one you have know. hope this helps you i got a used head for a guys truck i was working on and figured that out . he had a burnt valve and got a 86 22r head and tried to put it on a 84 22r and found out about the pistons hitting the head. you can't even bolt the head down rite.
Old May 11, 2003 | 04:30 AM
tystoy's Avatar
ok thanks man
Old May 12, 2003 | 05:33 PM
tystoy's Avatar
what would happen if I put an 83 head on an 87 moter. the pistons are flat tom so they won't hit the head but the compresion would be wrong. Right????
markwink
Aug 18, 2015 12:38 PM
viesail
Aug 17, 2015 08:39 PM
JAmdor3
Aug 11, 2015 10:53 AM
thefishguy77
Aug 9, 2015 04:15 PM
4Runnin2000
Jul 29, 2015 06:09 PM
