22r 2wd twice as fast as 22r 4wd?
My buddy has a
86' 22r 2wd with 30in mud terrains and 3.73 gears w/ 4 speed tranny,
and a
86' 22r 4wd with 31in all terrains and 4.10 gears w/ 5speed tranny
The 4wd is very much slower, could there be somthing wrong with the carb on the 4wd, or is it just the weight difference, or gearing(tranny/axle)? Just curious if others are having the same preformence. The 2wd is pretty darn quick, and you can really feel the second barrel in carb kick in.
and a
the weight is indeed a huge factor, but I think the gearing is huge. IIRC, the 4speed tranny is quite high geared.
I know my '89 22R 2WD on 31's would blow the doors off my '93 3VZE 4Runner 4WD... (and that '89 was HEAVY)
My 2wd is a lot faster than my 4x4 with the same engine (both California smog carbureted 22R). The 2wd is geared higher and I am sure there is less resistance because of smaller tires and a more simple drive train. The 2wd is about 400 lbs lighter according to the pink slips.
polo451
13
Nov 20, 2016 07:49 PM
landrunner
Aug 5, 2015 09:18 PM
