Manual locking hub conversion for 02 tacoma
Old Jan 22, 2007 | 06:49 AM
yotamaster1988's Avatar
Question Manual locking hub conversion for 02 tacoma
is there any company that offers a manuale locking hub conversion kit for my 2002 tacoma 4x4?
im tired of those dam cv axle rotating all the time and with my 2 1/2" coil spacer it all gives me horrible gas mileage
i think that the add and the constantly rotating cv axles was a bad idea on toyota part
they should still come with manual hubs or at least offer it as an option on the newer vechiles
Old Jan 22, 2007 | 07:06 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
search around, theres lots of information on this. im pretty sure you can get some warns or aisins fitted in there. IIRC, you need new CVs to handle it and if you have ABS, you need to do more expensive work. You'd also probably want to look into disabling your add after that as you wouldn't need it and thats one less thing to break.
Old Jan 22, 2007 | 08:03 AM
Bighead's Avatar
Off Road Solutions
It's not cheap and don't expect a dramatic increase in gas mileage.
Old Jan 22, 2007 | 10:16 AM
Flygtenstein's Avatar
Do not do that modification for fuel economy.
It is a strength and simplicity thing.
Old Jan 22, 2007 | 10:22 AM
then what do yall reckon is causing me to get such bad gas mileage
Old Jan 22, 2007 | 10:32 AM
4Crawler's Avatar
I assume the lift was accompanied by taller tires? If so, that causes the engine to work harder for a given speed and you are actually driving faster than the speedo shows and farther than the odo meter registers, so account for both of those issues. FInally lift = more frontal area = more wind resistance = lower gas mileage.
deepmarsh
Aug 6, 2015 03:44 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
ItsJustD
Jul 7, 2015 07:49 AM
