22R = 22RE Head studs?
can someone confirm for me that head studs for a 22R will work on a 22RE...or rather 22RTE. Everywhere I've looked I can only find ARP head studs for 22R's.
I know that 20R and early 22R's have shorter head bolts. But studs have "adjustable length", so it shouldn't matter. I'm 99% sure they will work, I just want to make sure before I drop $126 on fasteners.
Excellent,, I appreciate the help. Now for my follow up question, Do you know/anyone else know where a guy could buy just a single one? I had a set that pulled a thread out of the block itself and when trying to get it out I messed the head up on it and cant find a replacement anywhere local so far, anyone have any ideas?
Wrong, they were longer. 22RE head bolts are shorter.
From LCE website:
20R/22R OEM Head Bolt Set 1975-1984
This head bolt set will be about 200 thousands longer for the early engines. If you have decked the block and head you will be able to use the late style bolts part number 1024063 for a less expensive alternative.
From LCE website:
Sep 4, 2015 09:27 AM
