Question about 2.4 liter
Old Jan 5, 2007 | 04:14 AM
mtrdrms's Avatar
Well I have developed quite a leak lately in my tacoma. It first appeared to be coming from the oil pan gasket but I replaced that and nothing has changed. Now it looks like it is coming from the aluminum oil filter adapter that bolts to the block. Is there a gasket between this and the block? Has anyone had this problem? It is leaking a drip every 5 minutes or so so it needs to be addressed. Thanks
Andy
Old Jan 5, 2007 | 04:18 AM
19RUNNER86's Avatar
yeah i think there is a gasket in there. call your local dealer and they should be able to help you out cheaply.
Old Jan 5, 2007 | 06:19 AM
mtrdrms's Avatar
The bolt that I took out is huge and it has holes in it like a banjo bolt. Does that mean it has to be oriented a certain way upon installation? Or should I just tighten it up?
Old Jan 5, 2007 | 06:32 AM
19RUNNER86's Avatar
if you can find a service manual check for torque if not you could fudge it...but def dont lose the copper gasket.
Old Jan 5, 2007 | 07:44 AM
mtrdrms's Avatar
Good call. It looks like that is where the leak was coming from but I'm putting it back together now so we will see.
the1998sr5
15
Jul 14, 2020 08:35 PM
Swim
9
Jan 4, 2016 10:47 AM
coleypull15
Nov 3, 2015 07:41 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
Cplmike
Jul 8, 2015 08:47 PM
