clutch question
clutch question
Are 22r clutch kits and transmission same as the 22r toyota celica/celica turbo . I have a 88 22RTE 5speed 2WD and looking for a clutch. Any help will be appreicated.. thanks
The 22r/22re clutch and the 22rte clutch are different... The 22rte has a larger clutch and the two are not compatible! Many, many clutch vendors have them listed incorrectly, btw - you need to compare the SIZE of the clutch, otherwise you'll get something you can't use.
The 22rte is a 236mm clutch/pp.
The 22r/22re is 224mm clutch/pp.
I've got photos of the differences at the top of this page:
http://lakebox.dnsalias.com/photos/1...2rte-teardown/
I just bought both clutchs and compared them..
It looks like the they both look the same but clutch disc is just a bit thicker/wider, I'll try to have some picture up..
I"m guessing the celica, PU, 4X4 are all different clutches.
the1998sr5
15
Jul 14, 2020 08:35 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
